DC option issue
Hi
I have a problem with DC option cart display The rwamoore told me to drop a ruby code into the extension folder and the fix it , but i don’t know how to do it Can any one to tell me how to do it or how to fix the bug more easily?
this is the code
Regards Kostas
I can’t test this as I am on mac, Gemini says:
In Windows for SketchUp 2026, the default extensions (plugins) folder is located in the user’s hidden AppData directory.
Default Extensions Path:
C:\Users\YourUsername\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp\Plugins
How to Access the Folder:
Because AppData is a hidden folder, you can access it quickly by:
Opening File Explorer.
Typing %AppData% into the address bar and hitting Enter.
Navigating through: SketchUp > SketchUp 2026 > SketchUp > Plugins.
When you find the folder put this file in it.
Dans_dc_patch.rb (164 Bytes)
Hi rwamoore
Thank you for your indication For the moment it’s ok If i have any problem again i let you know
Regards Kostas
