I am working on a DC with a top rail with adjustable incline that requires an angled cut. I have that sorted. The problem I have is the bounding box of the angled cut piece impacts on the DC bounding box x-axis size, this then makes the scale function / LenX return incorrect values which also change with the top rail incline setting. The dashed line on the image is the bounding box of the angled cut piece which is pushing out the bounding box of the component from what should be flush with the pale blue box.
I got around this on a solid rail with two pieces with axes set to match the component. That isn’t going to work with a complex profile rail… Any suggestions to stop the angled cut bounding box over hanging whilst still being able to change the incline?
