Cutlist Stopped Working
Ok that worked. I installed in the proper slot. Double checked to see if it was the correct gui. Attempted to run SU with the nominal thickness margin with no value, but got the same result, i.e. no output. Put a value back in and voila it ran.
That’s odd…
Two questions:
  • did you put it into your personal Library, not the system one /Library (your personal Library is hidden by default in Finder)
  • were you running SketchUp 2017 when you tried it?
Yes and yes.
I restarted SU and Cutlist now works properly after install the new gui.rz. Thanks for your help. I think we can call this matter solved!
Ah yes, I forgot that: SketchUp didn’t reload the modified file until you restarted it! Glad it is sorted.
