I drew the whole closet. But I didn’t make Component. Now when I go into the cut list everything is blank. Is there any clever way to create a Component afterwards?
You’ll have to go through the model and select the edges and faces to create the components. There’s no automated way to do that. Depending on what you modeled, it might actually be easier to start over and create the model correctly rather than trying to repair what you’ve already done.
What version of SketchUp are you really using? Your forum profile says you are using SketchUp Free (web) 2023. There is no such thing and there’s no cutlist option for the web version. Are you using a cracked version?
I use Android version of cut list
the android version ?
do you have a link to that ?
I’d be interested in that, too.
I presume you are a hobbyist woodworker since you are using SketchUp Free. Maybe the simplest route for you now would be to just manually write out your cutlist. I bet you could do that faster than redoing the model.
SketchCut app
It’s not clear from the website how it works with a SketchUp model.
Uuhh, I’m pretty sure you’re on the wrong forum, this one is a bout Sketch UP not CUT ![]()
