I’m have MSI Creator 17 with Nividia RTX 2070 Max Q Design, the problem is that the graphic card is working fine except for one program which is Sketchup and Vray.
It’s mentionned in the error log that I need to update my graphic card driver, even if I have the last version installed which is “457.34”
Error log: “Failed to initialize OptiX (check your driver version. OptiX requires NVidia driver 466.11 or later)! Error Code : 7801”
That is not the latest. I have RTX 2070 and my driver version is 511.something, and there might already be a newer one. Go to the Nvidia site for drivers, not MSI.
What version of SketchUp are you using? Your profile says you are using SketchUp Free (web). If that’s the case, it might also be important as to which browser you are you using.
