Creating smooth animation transition between scenes
Hello again, probably this is a very old problem to you all. I created four scenes with transition time 3s and delay 0 . See exported video … you can clearly see the abrupt unsmooth transition from scene to scene. Speaking in 2d it should be a curved transition not angular. Can I do this with ACT ? presumably not. Any professional plugin you can suggest ? Dont want to have to much work in postproduction :sweat_smile: Thank you Adrian
Hey, try more scenes closer together with short transitions, speed it up in post if you need to.
Thank you Ryan, i tried this and it is a easy and sufficient solution. :+1: Thank you ! Adrian
If you set the overall scene delay to 0, then you can adjust the transition time to the speed you desire.
