Crashes when exporting dwg or dxf or pdf, pdf is not responding ,
iHello,
I am having trouble exporting some layout files to PDF, I keep getting “not responding” then it crashes.
I have a file which will not export as DWG or DXF, sketch up crashes before the export is complete.
I get a bugsplat when I reopen the sketch up file to repeat.
Can you please help, please see a link to a document that I am having trouble with. have a large file of 87 mb, i dont know how to decrease the size of file.
i added the link for my file
Help.
I’m using macbook pro.
jury file
SketchUp for Schools is web based and don’t have LayOut. What version are you using?
Have you sent the blugsplat to Trimble?
i have been using sketchup pro 2021 version, i sent the blugsplat to trimble yes
Is that a cracked version of SketchUp 2021?
Please update your forum profile with the right information.
Your file is large, so your model is probably bloated. Try switching all model viewports to use Raster rendering when exporting to PDF. Set Output Quality to High and don’t use JPEG compression.
My model is not export into dwg/dxf/pdf not in the layout
iam new to this forum profile i will check with it
can you please see what is the problem with my file
i updated my profile please check what the issue with my file i moved the model close to origin and also used cleanup pluggin to clean yet my file is large
final jury file.1
I found incorrect tag usage, overly large texture images and a lot of detail. It does work in LayOut 2024 although still slow even after cleaning up the model some. I would suggest you upgrade to SketchUp/LayOut 2024.
Not Responding doesn’t mean SketchUp or LayOut has crashed. It just means it’s busy doing what you asked it to do. This is a vector-rendered viewport in LayOut. It took some time to render due to the large number of edges but it did it.
