Hi there, I can’t get sketchup warehouse extension library to work anymore on the 2016 pro version to download a converter and I have two 2017 files I need to save down. The web platform only allows down to 2017 so I feel stuck. Can anyone help me?
https://we.tl/t-LeYTFPlqGk
Thanks in advance!
hello, have a look at this plugin Extension | SketchUp Extension Warehouse
install it, then a new “open newer version” will appear in the file menu
you will then be able to open any model downloaded from 3d warehouse, even as newer versions
Hi, its easy! You only need to:
- File
- Export
- 3d Model
- Expora a .dae file…
On Sketchup 16 you need to “import” de dae file…
I was fighting with my old PC to be able to record the SD card directly from that PC to use the card in the 3D plastic printer… and it worked super well
Best Regards,
Ariel
