Component jumps to 0,0
Hi
Any chance that somebody has any idea why this component jumps to 0,0
As soon as I click on in it and it can not snap to the mouse pointer and cannot be drag to correct location
AC Control.skp (39.0 KB)
Are you referring to the Dynamic Component?
It has been geolocated. Clear that and it will work.
In addition to removing the geo-location, if you are trying to change the height of the wall element, it’s position is fixed in the Dynamic Component attributes.
no geo loc in my setup
no geo loc
Open the component in it’s own file. It is geo-located.
Download the file you shared and open it.
I can Adjust Z pos
Thanks Dave
it is geo loc
done - no problem thanks
:slight_smile:
It would be helpful if you mark the post made by @Box as the solution so others who might have the same problem will get help.
Box gave the solution in his post. You should mark his post as the solution, not your own.
Now you’ve marked my reply as the solution. That post is NOT the solution to your original problem.
Ok
I think I got it this time
Thanks
Not quite. You’ve marked another one of my posts as the solution. Since Box posted the solution first, you should mark his post as the solution.
Ok
How about this time?
Yes. Now you’ve got it.
Thank you.
