Colors/textures
hello,
please help:
I can find a number of different codes to every color I want, for example:
but the nodes COLOR or SET COLOR only allow the numbers between 0-1
how to set the color I want?
thank you
Hello
Here an example to compute RGB color from value 0-255 to 0-1
https://creator.trimble.com/graph?assetURI=whp:0696bdff-c3ed-410e-951a-48b45b9204e9
You can past a hexa color string and convert in color with this graph
https://creator.trimble.com/graph?assetURI=whp:d7d01c82-43b0-4647-bd20-970bdc9337c6
Clean string with no blanck, without the # char
After convert letter to decimal value
Multiply by 16 the first, third and fifth
r = 1+2
v = 3+4
b = 5+6
normalize vector et get the color
hello simjoubert,
thanks :+1:, but this way of setting colors is too much/too complicated for me…not your fault :wink:
maybe the easiest way will be to just simply paste a texture with the color/s I need.
Hi! Understandably colors and their numerical values are a little confusing, especially when we seem to use our own “version”.
When using the color-picker by clicking on the colored strip or box:
You can define a particular color without the need to know the full “0-1” dealio.
One thing to note is that a vector is just a 3 component value. Which depending on the context it is used in can have different meanings. (a vector can be a point/position, movement, rotation, directions, or in this case, a color). An RGB defined color value is just a vector where R=X, G=Y, and B=Z. Colors in Creator are on a 0-1 range, but is equivalent to the 0-255 range in RGB (as Sim explained, and has a great conversion method!).
Here is another graph that I made a little while ago to visualise the whole 0-1 scale thing with respect to a box of colors: Trimble Creator
In the mean time I’ll be sure to submit an issue with the team to see what we can do to make this easier to understand! Thanks for the feedback!
Hi - I’m just getting into live components. How do I scale a texture? I’ve worked out how to apply a material and its various maps but it’s a teeny weeny scale and doesn’t look right in my model or renders. I tried adjusting the scale of the wood texture I am using in the downloaded Sketchup model of the component, which appeared to work fine, but when I import this into my house model the texture is still the very small scale. I can’t seem to adjust it in the house model as it’s not in the list of materials, presumably because it’s reading the information from Creator? Just guessing…
