I created a dae file in photoshop and tried importing it in my sketchup model. each time i do so it say import failed. it use to work now it doesnt. i NEED HELP!!!
Help us to help you.
What is this DAE.
Can you attach it ?
How can you do that?
The file must contain a 3D model for SketchUp to be able to import it.
Can you post the file?
Anssi
Photoshop Extended does 3dā¦
hereās the file that was created in photoshop. photoshop has an extension where u can create a 3D model from layers. and hereās the screenshot
CheersSign.dae (510.1 KB)
Missing Textures-
/Users/johns_iMac/Downloads/Layer 1 Extrusion Material - Default Texture.PNG
/Users/johns_iMac/Downloads/Layer 1.PNG
and then it failsā¦
I have those materials in the folder that the .dae file is in
It crashes Meshlab as well, is it tiny?
if youāre referring to the thing in photoshop no. it just doesnt import into my sketchup model
[quote=ājohn_drivenupthewall, post:6, topic:16127, full:trueā]
Missing Textures-/Users/johns_iMac/Downloads/Layer 1 Extrusion Material - Default Texture.PNG/Users/johns_iMac/Downloads/Layer 1.PNG
and then it failsā¦
[/quote] @damar_prince
Please upload the WHOLE āDAEā package - including the required material image files.
Without those we are doomed to fail ![]()
Enitre package
CheersDae.zip (1.2 MB)
have you tried exporting without the āInfinite planeā as the ground? and your still missing a file āLayer 1.PNGā
no i didnt. how do u do that?
no idea Iām just reading the code, and thought why export a ground plane with a material if itās not need in the final importā¦
I donāt use photoshopā¦
what do you suggest i do to make this work?
Iād draw it in SU and just apply the image as a textureā¦
thats very complex to draw
what else can you export that SU can import? 3ds? dxf?
.kmz files, 3ds files .dxf files
try one of eachā¦
.kmz will probably fail as itās also a .dae insideā¦
