I use Cleanup3 all the time but for some reason it now takes a long time to process. Something that would normally take 2-3 seconds is taking 3 minutes. I am on a M1 Max Mac Studio. Sketchup runs good it is just this essential tool which lags. Is there something I can do to try to fix it?
The file has more stuff OR you maybe have the “delete duplicate faces” box ticked, which always takes a long time vs not using it (sometimes HOURS)
The thing is I can run cleanup3 on my pc on the same model and it is still a 2-3 second deal (maybe 10 seconds sometimes but never much more than that). The complexity of the model has to be a bit high due to it being a house. I also keep my models super clean. It just seems like it is just not working right with Cleanup on the M1. I tried turning off the merge coplanar but it did mot help.
Just did a test on the same model. I draw a line on the wall of the house. Grab everything and run cleanup3. On the M1 it takes 58 seconds and 1 second on the PC. Attached are the settings for each. Maybe uninstall the extensions and re-install?
Good old uninstall and reinstall fixed it. I deleted the extensions and re-installed. If it aint working unplug it and plug it back in. Works 90% of the time
