Classic license 2018 pro
Hi,
I own a SketchUp Pro 2018 Classic (perpetual) licence, serial starting TA-, and I’m trying to activate it on my iMac.
What I’ve done so far:
  • Installed SketchUp Pro 2018 from the official link
  • Fixed the “Bummer, it looks like you’re offline” error by changing ONLINE_TEST_URL in i18n.dat to bing.com
  • Cleared ~/Library/Application Support/SketchUp 2018/WebCache
  • Restarted / force-quit several times
The Welcome window now shows “Licensed To: SketchUp Pro 2018 User, Expired”. When I click Add License, the License panel stays completely blank, so there’s nowhere to enter my serial number and authorization code. Screenshot attached.
In the last two days, three topics have been opened regarding this same issue with the older Classic versions like 2018, 2019, 2020.
I assume there is a temporary issue with the associated server on Trimble’s end—or, hopefully, nothing worse…
Your 2018 license is activated on three computers. The failures you’re seeing may be because of that. You could try removing the license from one of the computers that you’re not using any more, then see if it adds the license ok. I will message you with information on the three machines, in the hope that you then remember which computers have the license.
If the iMac you’re trying now is the same iMac you added the license to in 2017, I may be able to help fix that. Let me know if it is the same iMac when you reply to my message.
Hi Colin
Great that you have come back to me.
I don’t think i have the three machines any more
My main machine is a M3 imac
If that is any help
Cheers Simon
The M3 iMac isn’t going to be the one from 2017, and so would be a fourth computer you are trying to add the license to.
If you can get through to Support you could ask if there is something they can do. Some people had problems getting through, but here is the link if you want to try:
https://help.sketchup.com/en/contact-support/technical-question/form
I do have an imac from 2017 so that may well be but how do i deregister it.
Thanks
Simon
If you can open SketchUp and remove the license, that should free up one activation to use on the new iMac.
I accidently deleted my original copy of 2018 on this computer and downloaded a 2018 version from the web. could it be anything to do with that. Is there a safe place to download a 2018 version. The version I have now i cant do anything with. Also tried to contact sketchup but cant get through to anyone. A bit stuck now.
Cheers Simon
Don’t forget that you will have to do the ONLINE_TEST_URL fix in the version you downloaded. What goes wrong when you try running that version?
This happens after I click big red sign saying license then nothing this screen is doesnt let me enter anything. As I say I tried to contact Sketcup but the link you gave me didnt work. I would like all those old machines to be deregistered. I was using sketcup 2018 on the 2017 imac but becuase I deleted the program and installed the new 2018 its not working. It is a bit off that sketchup sells a perpetual license and then its not perpetual at all. Sounds like a miss sell. They should have said 9years only or something similar.
I hope this is usefull info
Simon
I have tested 2018, 2019, 2020, 2021, and 2021 is the only one not showing the blank screen. I am trying to find out from colleagues if there is a known problem happening.
Unsupported browser for the older versions?
No doubt something at the server end of things has made Chromium 64 stop working. 2021 was updated to Chromium 88.
Dear support, have any solution already?
The issue is almost 1 week already. Thanks.
Any joy on this one can not they cancel the machine license from there end.
Someone replied to your post.
| colin SketchUp Team
October 9 |
Hi Colin,
I’ve made some progress investigating my SketchUp Pro 2018 licence.
I have the hard drive from my original Windows PC, although the computer itself no longer exists.
I’ve found what appears to be the original licence file at:
D:\ProgramData\SketchUp\SketchUp 2018\SketchUp.lic
It’s dated 2019 and contains information identifying it as a permanent Trimble SketchUp Pro licence.
I’ve also applied the ONLINE_TEST_URL fix to SketchUp 2018 on my current Windows PC, but it still reports that I may be offline and opens in trial mode.
Is there a way to release the activation associated with the old Windows computer, given that I still have its original hard drive but cannot run the original machine?
My aim is to get my existing SketchUp Pro 2018 licence working again on my iMac or current pc
Many thanks.
Simon
We are sorry, but you do not have access to support cases.
Please contact your organization’s administrator for more information.
Cant reach support page after register, want to open ticket also disallow…
That’s because your original purchase came with 12 months of support and the software itself is no longer supported by Trimble.
Hi Colin
Maybe I could have a 2021 license if the others dont work.
Thanks Simon
