Change Plane of Inserted CAD File
I want to be able to rotate a building section that I’ve inserted from CAD around the x axis. Can I do this?
Have plan inserted which I’m referencing walls from.
Would also like to be able to move my 2d buidling section onto the walls of the sketchup model so I can reference my openings, floor elevations etc.
You can use the Move and Rotate tools on any imported object to position or orient it however you wish.
Unless you exploded it, I would surmise your .dwg or .dxf came in as a group, so it should behave like a single object.
-Gully
After seeing your post I almost immediately realized that I had locked the plan. Thus, couldn’t rotate.
Thanks for giving me a reason to rethink this.
Not the sharpest tool in the shed!
