D Hexagon Jan 6 Trapezoid Problem.skp (136.8 KB)
Hello,
The attached model has a trapezoid that I have selected. Only part of it is dotted. Why is that?
I am trying to push that window out. Why can’t I do that?
Peter Enns
Hello,
Peter Enns
Z-fighting. There are two faces at the same or almost same place.
It appears there is a face on top of a group. Delete the extra edges you don’t need as you only need to push/pull from one side to cut an opening on the other. Also be sure to ‘reverse faces’ as you go so there are no blue (back) faces oriented outward (it’ll help you later, trust me).
It almost worked but not quite. I erased the solid lines on the front & back. The entire trapezoid was dotted. Then I began pushing it out as you can see in the attachment.
However, when I got to the solid line at the top & back of the hexagon, it would not push out. Why not?
Peter Enns
From a year ago:
Time to revisit SketchUp’s modeling Fundamentals again then.
