Can't draw a simple rectangle
When I attempt to draw a rectangle in a new, blank document nothing happens. I.e. the tool appears, but when I click and drag no lines appear. This was never an issue before SU23. Am I missing something obvious?
What version of SketchUp are you using now? Your profile says SketchUp 2021. What graphics card. “NA” doesn’t tell us anything useful.
What style are you using?
Draw a rectangle in a new file, save the file, and then share it so we can see exactly what you’ve got.
I’m using SketchUp 2024 on a Mac Mini M4 Pro.
Style is Shaded with Textures.
Screen recording attached.
Please fix your forum profile. It isn’t even close.
Which gaphics engine are you using? Look in SketchUp’s Settings>Graphics. Change to the other graphics engine, quite, and restart SketchUp. Then try again.
Switching to the classic graphics engine did the trick. Thanks!
As for the forum profile, where do I update that? It isn’t immediately obvious…
Excellent! And you’re welcome.
Click on the M in the blue circle at the top right corner of the forum window. Then the person icon, Preferences, Profile. Make sure after you update the information that you scroll to the bottom and click the Save button.
The symptom you’re showing was fixed at some point. Is there a reason you’re using 2024 and not 2025?
