There is something going on with my sketchup. I am using 24. I am curious if anyone else is having a similar issue. Once I am working in a file for a bit. Sometimes 5 minutes or even 2 hours. There comes a time that i cannot create or even alter components (make unique). I have to close the file and re-open to work. The last time it happened very quick. This is getting annoying. I have noticed it happening more often. Is there anything that I can do to avoid this? Just wondering if it is a glitch with 2024. This has never happened in prior years.
Maybe one of your extensions is doing something funky in the background? Open up the Ruby Console (Extensions β Developer β Ruby Console). Is anything there? What about after using SU/extensions for awhile? There may be a clue there to help you run down this problem.
I have not experienced or heard of this problem before. Next time you reach a point where new components refuse to form or you canβt make unique (note: there must be multiple instances of a given component to use the make unique function) then save the file and post it here so we can see if it behaves the same. Are you saying that when you right click the make component option is unavailable?
Hi Trevor.
It seems you are using the Classification Overlay feature from the latest version of 5D+ Plus and it is causing an issue with the right-click menu. I am investigating to find out and fix this soon.
Sorry for the inconvenience.
Thank you for the info. It isnt a big deal. Has only happened a handful of times.
