Im here again with another array problem. Im sure it has something to do with the circles not winding up on the same edges based on the number of circles copied but I wanted to hit the forums and see what you guys had to say. I want to attempt to make a model of a little engine that my dad made and even just drawing the wheel, I am having problems with the array. I created the 1 circle, and then did a rotate copy (360° /5) but then when I get rid of the circle I used as the pattern and try to push/pull, the other 4 circles just move with the part. Do you know why?
Did you delete the faces inside the small circles (so they become holes) before doing the pushpull?
Well that seemed to do it. Didn’t know that’s what I needed to do beforehand. Thank you for the information.
