Cannot find components. I click on entity info and it tells me I have 7 internal doors, but I cant find them anyway. Ive reduced the size to see if they are someone else in my project but i cant see them at all. I’ve read all the answers here and have tried all the fixers. I can see them when I put them in a blank project. I’ve attached the link to my project if anyone can find my doors I’d appreciate it. I’ve attached the link here my project
Can’t tell anything viewing your model in the online viewer. Share the actual .skp file.
One thing I do see is that your model is absolutely enormous. The walls are almost 3 Km tall. If you inserted real world sized doors into this model it would be not surprising that they don’t show up. The length of the wall mesaured here is more than 6 Kilometers.
Your profile shows you are using the free web version. Is that correct?
yes thats right, web version. Oh wow, I hadnt realised that, i was trying to make them 2700mm high. ill try and see if i can check that, thank you. i have uploaded the skp file, sorry didnt realise that either! ![]()
my house.skp (4.1 MB)
So I assume this is a hobby thing for you?
Here you can see the ridiculously large dimensions that you’ve used.
There are a numbver of components in the model however they are spread across the planet so they won’t appear if you delete your origninal geometry.
Probably the best option for you is to start over modeling your walls at the correct dimensions before you even think about imserting anything from the 3D Wareouse. Also consider that faces in SKetchUp have no thickness. In your model the “walls” are zero thickness which doesn’t relfect reality.
Yes that’s what im doing now. Ive changed it to millimetres not metres! Yes it is a hobby. In 2016 I designed my whole house that was being built and had no problems and loved it. I am building again and want to do the same. However things have changed somewhat in that time. Anyway, thank you for your assistance. It is appreciated
Karen
ah thank you, yes i realise it now, thought there had to be an easy answer. oh well back to the drawing board. thank you both again
