Cannot draw on axis
I can be drawing using all 3 axis,blue, green and red, then suddenly I can not draw on say green, it varies. It tends to come back after a while; think I have inadvertently done something by mistake, can u help?
Could you have pressed one of the arrow keys on the keyboard? These lock in a particular direction, the locked axis should be highlighted. Otherwise you may be expierencing the inference engine “helping” you.
It might also be the position/angle you are facing. If you orientate the view to the axis you want to draw on that makes a difference, or you can force a specific axis/plane by using the arrow keys.
thanks for your reply…I can force it to select the green axis through pressing the arrow keys, which is great but a little perplexed why it will not select green axis by its self.
thanks for your reply, it works!
Unfortunately you’ll not see intersections between geometry (nor guides) and any of the axes just by having them cross the axes. You’ll have to pick up (=reactivate) the inference to drawing on an axis by hovering over the origin first. Maybe you’ll even need to switch to X-Ray first if the origin is covered/blocked. Once you have SketchUp’s focus on the axes again, you can draw on axis and or find their desired intersections with existing geometry and guides.
After a while and some other operations SketchUp may forget its focus on the axes again
I sometimes put guide lines along the axes to make it easier to get inferences to them, as the origin is often beneath something and far away from where I want the inference.
