I’ve used a glass door component onto my drawing and have successfully managed to delete the faces on the two outer glass doors, however the middle section the face just will not delete.
If I try to select it to delete, it selects the entire wall.
with out the model its hard to say. Was the door an imported model from the 3DW? a link to the model would even help. I’d say the wall opening should have been created first.
You could select the door and hide it. Edit the wall then unhide the doors component.
The best way to get help is to upload your model here. 7th icon from the left in the reply interface. If the file is too large there are other ways.
Without seeing your SKP file, I’m taking a stab but I’m guessing you need to trace a rectangle onto the wall where the opening in the door is and the select the face inside that rectangle and delete.
oh good glad you managed. I moved the door out of the way and made an opening in the wall. I deleted a lot of geometry that looks like another copy of the door there that you exploded. All your walls , floors etc are all loose geometry. I think you’d find it easier next time to create groups and components to keep geometry from merging.
Any way now you know how to upload the models have fun
anyway I uploaded the model to 3DW under csm±+kitchen
