I recently lost all files on external hard drive, but managed to recover the majority of them. However, my original .skp files are not there, just the .skb files. I have googled this issue so much, and tried everything (the latest being renaming the file as .skp). This changed the file type to a Sketchup Model, but sketchup still does not recognise it when I try to open it! Please help! This is the only backup I have and it is quite urgent that I can access it.
Sorry. Judging by the size of the file I can guess there is a lot of work put into that file. I hope someone else can help you. I was going to try to import into AutoCAD with their .skp import extension but I could not get the AutodeskImportSkp.msi to work on a Mac. Maybe someone can try on a PC. Even if that worked, file would need a ton of clean up but it would be something.
Not a problem, guys, thankyou so much for your help! A lot of my files came back corrupted when I recovered them, but I hoped that this wouldn’t be. Never mind… Leaves me with a new project to work on!
I just had a thought, may be useless…
create a new .skp with almost the same name, beside the .skb…
e.g. great_model_1.skp and great_model.skb
close SU
rename great_model_1.skp to great_model.skp
open it in SU
select File Revert and see if it imports from great_model.skb
maybe…
john
