Hello.
First… Sorry for my bad english! Can I write in german language here?
Second… This is my first post here. I hope this is at the right place.
Then…My problem…
I have a .skp wich i can not open.
The error is:
“Es scheint sich nicht um eine SketchUp-Modell zu handeln.”
If I want to import this file, the error is:
“Datei nicht gefunden oder ungültig.”
Sorry, I have download Sketchup Make 2017 for a long time.
I think its from the sketchup website.
I never paid for it, so I think here in “Sketchup Free” is the right place.
This file (Ufoversuch.skp) I have created myself.
Hmm…???
I can not upload this file.
“Processing Upload” since over 30minutes.
Hmmm, now, when I want to copy the file, there is an error.
Google says, I had to check the USB drive.
Windows want to repair it.
I will try this.
Perhaps I can open the file then.
An Upload to Dropbox or other sites I haven’t tried yet.
First I will try to repair the USB Stick.
No…the project in this file is not big. Something for 3D Printing.
But I needed houres and days to build it.
So you’ve been saving the file to a USB drive? That’s probably the issue. You should never work on files saved directly to USB drives or other locations that are not internal to the computer.
I’m working at two diffrent PC’s.
At every PC is the same version of Sketchup Make 2017 installed.
Saving in a cloud is no option.
So I have to save at USB Stick.
This is the first time that I have a problem like that.
I use Sketchup since 2010.
But…never had such a problem.
If this “repair thing” won’t work, I had to build this “Thing” once again.
And Yes…I hope I get it quicker this time.
Save the file to the internal drive. Copy it to the USB stick when you need to take it to your other computer. Copy it from the USB stick to that computer’s drive before opennig it and working on it.
Looks like it’s been corrupted by the issues you had with the USB memory stick. At this point I would suggest you move on and redo the model correctly making sure you are saving it to the internal drive on your computer.
USB sticks wear out much faster than traditional hard drives when used for continuous saves. Applications often keep reading and writing temp data to the drive where an open document is stored. That is why they should be used only for backing up and transporting data.
Du musst deine Sketchup Dokumente auf deiner Computer internen SSD oder HDD speichern.
Es ist bekannt, dass das Speichern des Dokuments auf einem externen Gerät solche Probleme verursacht
