Can not correct text in layout
Hello,
Using SU15, mac.OS10 I am unable to correct text in layout. I can delete all the text but not an individual letter.
I have been using LO for quite awhile and have not had this problem until today. Also noticed that the curser
does not blink (or even show up) when I start to insert text.
Did I hit a key that I didn’t realize.
Thank you,
Pete
Are you opening the text box to access the actual text?
Is the text under a viewport or something?
Maybe you could share the LO file so we can see what you’ve got going on?
Sorry for the delayed response back to your suggestions, I have been traveling. I have corrected the issue by shutting everything down and restarting. Still don’t know what I did to trigger it.
Thank you.
That sounds like the standard Windows repair. Are you sure you’re running a Mac? :smiley:
I hear you there. I figure I must of hit an additional key when I was typing caused it. Have a Merry Christmas, I appreciate advice and solutions you given in the past.
Merry Christmas to you, too.
Cheers,
d
