Can I make two copied objects into components after I've placed them
Hi, I’m new to Sketchup and I’ve just found out I could use components to make a file lighter. I’m working on a project where I have a large number of objects copied from one object and already placed and it would be a lot of work to start over and place the objects again. My question is can I make the objects components after they have been placed? Thank you
Natively no… BUT
There is a great plugin called Component Replacer in the Extension Warehouse that will replace a selection of groups with component. All you need to do is…
… Make one of your groups a component
… Select all the remaining groups that need to be replaced
… Initiate the Component Replacer tool and sample the component.
—> All the selected groups should be replaced by multiple instances of the component. :smile:
I hope this helps
Cheers
CD
thanks man, this worked beautifully!
I’;m so happy about this, you’re awesome!
oh no. I am just the “messenger”. @tt_su and all the ruby authors are AWESOME!!
:smile:
object to create a copy just press Ctrl keyboard …
may be useful
