Can I just copy the layer folder?
大変お世話になっております。
また初歩的な質問で申し訳ございませんが
ご回答頂けますと幸いです。
現在、「床」、「壁」、「窓」レイヤを、階ごとにフォルダ管理しております。
しかし、新しいファイルにデータをコピーすると
フォルダの管理が無くなってしまいます。
フォルダのままコピーする方法はありますか?
よろしくお願いします。
(グーグル翻訳)
Thank you very much for your help.
I apologize for asking such a basic question, but
I would appreciate your answer.
Currently, I manage the “floor”, “wall”, and “window” layers in folders for each floor.
However, when I copy the data to a new file
the folder management is lost.
Is there a way to copy the data as folders?
Thank you in advance.
(Google Translate)
レイヤをそのままコピーしたい
レイヤをそのままコピーしたい2
When Tag Folder was added to Sketchup, it was decided that Tag Folder names do not need to be unique. So it is possible that e.g. there are any number of Tag Folders named as e.g. “Windows” or “Doors” in the model, but different Tags belong to them. This is good in many ways, and it can be handled well in that particular model.
However, it is quite difficult to write an algorithm that, if the target model also has several Tag Folders with the same name as the source model, which Tags under which Tag Folder should be placed. Perhaps that is why Sketchup does not support the transfer of Tag Folders by default.
A few algorithms have been posted here on the forum for exporting and importing Tag Folders, but none of them are bulletproof.
My best advise now is to add missing Tag Folders manually.
(Or - I know it is too late now for your current particular problem - create a template, containing your Tag-Folder structure, use it in all your model, so then copy-paste between them will not create such a problem…)
教えて頂いてありがとうございます。
私は理解しました。
物件が大きくなり管理するフォルダとレイヤが増えると
大変ですね。
早く、フォルダ毎、コピーできる機能が搭載される事を祈ります。
(グーグル翻訳)
Thank you for letting me know.
I understand now.
This problem becomes more difficult as the property gets larger and the number of folders and layers to manage increases.
I hope that a function to copy folders will be implemented soon.
(Google Translate)
