This is for the free web version of Sketchup.
Description
I started creating a new model, and the default app template was set to Architectural - Feet & Inches.
After a while, I didn’t want this setting anymore, so I changed it to Fractional - Inches. However, this setting change did not carry over to my existing file. I even tried duplicating the file to see if it would apply the new global app settings to it, and it doesn’t. Every time I take a measurement with the model that originally had Architectural - Feet & Inches as the setting, it keeps giving me the measurement in feet and inches, even though the current app setting is set to Fractional - Inches.
Steps to Reproduce
- Create a new file/model
- Open the App Menu in the upper left, and open App Settings
- Verify that the default value under Regional → Default Template is Architectural - Feet & Inches
- Create a basic object such as a rectangle, and make it larger than a foot such that the measurements show both feet and inches
- Open the App Menu and go to App Settings again, and now change the Default Template to Fractional - Inches
- Use the Tape Measure tool and measure the object you just created
Possibly related but may be irrelevant - the Model Info settings are also set to 1/2" format with a precision of 1/64".
Expected Result
The object measurements should be in inches and fractional inches only
Actual Result
The object still measures in feet and inches, as if the change to the Default Template didn’t apply
Other Thoughts
IMO, it’s odd for this setting to appear in the global file menu in the first place because there are other units settings in the model info panel which let you set precision and even switch to decimal format right there on the fly. It’s strange having to look in two different places for units and measurements settings. Perhaps all units and measurements settings could be consolidated down into one context panel, and then the regional formatting could apply on a per file basis instead of globally, with no way to apply it to existing files.
