I am using a Woodworking style and the Model Info is set to a 1/2" Format and 1/32" Precision and the Tape Measure units are feet and inches. I have seen older posts on this subject but none of those suggestions work. Nothing I have tried works. I tried a 30 day trial Pro version and it displays in inches only.
The Default Template is set to Fractional - Inches in App Settings and the Tape Measure still displays in feet and inches.
Now that you have the default set to Fractional-Inches, new files will show dimensions in inches. Save your existing model. Then start a new file and import the model into the new file.
New files now show measurements in inches but I can only import my current file as a component without upgrading.
You don’t need to upgrade, well, as long as you’re a hobbyist. Import it as a component and then explode the top level and you’ll be back to where you were in the original file but with inches as the units.
That worked like a charm. Thanks so much for your help DaveR!
