Best way to Import a Logo from Adobe illustrator into Sketchup
I started with an illustrator file provided by my employer Kawasaki and found a YouTube video to get my illustrator file into a .dwg file and bring the artwork into SU. Is there a cleaner way to import an adobe illustrator file into SketchUp Pro more directly than converting the file to a .dwg file first?
It probably doesn’t make a lot of difference. You need to get some sort of vector format to import into SU. .dwg or .dxf are probably as good as anything.
Getting a warning this time and it fails. "Warning:
Some imported geometry is extremely far from the
model origin. If you experience any instability with
your SketchUp model, please delete that geometry
from your .dwg/.dxf file and import again."
Try turning off Preserve Drawing Origin in the Import options.
LTGTR Logo Stand Alone Black.ai (1.1 MB)
DaveR: Still getting the error. :frowning:
I’m trying to make this into a 3D Logo object that I can glue to any vertical, horizontal or sloped surface.
Can you send me your .dwg file?
DaveR… I finally got it to work. I had to make sure “Preserve Appearance” was chosen when exporting to a .dwg file from adobe illustrator. I just kept trying different export options from illustrator.
I was about to tell you about that! Here’s another tip, do Add Anchor Points a few times, you’ll like the import better that way.
See my file.
kawasaki.skp (552.1 KB)
Colin,
Thanks for the tip. I’ll have to try adding anchor points in my next project. :slight_smile:
Mark
