Beginner Help, PathCopy, Rotation objects issue
Hey,
I have issue when i try to copy object to a circle path, the objects are in wrong angle.
I leave the picture as well.
Thanks!
Change the axes of the component.
And what color axes should i follow? Does is matter where is the new origin point is?
Using PathCopy, changing orientation of a component
Go to the Sketchup campus and SketchUp YouTube
Both offer great tutorials and videos that should help with your questions.
Thanks! Found the solution on this one. :slight_smile:
Just asking, why after component copy u made that original component unique and then changed the axis? When i tried to move the axis it will change the axis but the component position will remain the same.
I thought it would be easier to understand if both components were visible at the same time, the difference in axis orientation being clear.
After you change the axis orientation, you will need to apply (PathCopy) again to see the change. This is the second reason why I made two separate components.
Thanks, now it’s more than clear!
