SketchUp 2027 Copy Along Path how to set component axes for vertical path?
I’m playing around with the procedural copy along full path feature and I am having trouble figuring out how to set the axes for a component that I want to copy along a vertical curved path. When I run the same procedure with a flat arch path on the ground, I get the result i’m expecting, but when trying to do it vertically, the component just doesn’t rotate the way i expect. I know it has something to do with the procedural components’ local axes vs the copied component’s axes, but I can quite seem to figure out the correct combination that works or the logic behind it. Any ideas? (see attached video)
Copy Along Path follows the component’s own axes, not the model axes. On a flat arch those line up with the world, so the copies look right. On a vertical curve they do not, which is why the copies twist.
Right-click the component and choose Change Axes. Put the origin on the point that should sit on the path, aim the red axis along the first segment in the direction you want to travel, and aim the blue axis toward the side that should stay outward from the curve rather than world up. Run Copy Along Path again from that same end. Starting from the other end flips the tangent, so the rotation looks mirrored.
I seem to be missing something as it’s still not working the way I’d expect. I tried with your instructions and the component still always ends right side up, facing in the same vertical direction. See attached video. I also tried putting the component on the other end of the path, tried putting the path on the other side of the wall, tried other local axis configurations - none rotate the component so that it’s perpendicular to the segment. What am I doing wrong? :slight_smile:
In the entity info, controls, is an orientation option, where you can choose stair like and road like. That is only yaw, or yaw and pitch. To get the object to orient to the vertical version you need road like.
Colin, is this problem encountered and known?
By exploding the path and shifting the vertex just slightly, the orientation of the objects is resolved.
Hi Colin! Thanks for your reply. I tried changing it to road-like as well, and the result was closer but still not quite right (see video) - any other ideas?
oh! just saw this - thank you! will try this out!
I’m not sure, I will ask that team.
Another solution seems to be to make the object on the ground, then rotate it 90 degrees.
It can also be done just by changing the orientation of the axes.
Road-like only adds pitch on top of yaw, so the component’s blue axis still tries to stay as close to world-up as it can. On a vertical curve that up-vector is nearly parallel to the path tangent, which is why the copies stay right-side up instead of turning perpendicular to each segment.
The ground-then-rotate workaround avoids that singularity: model the piece flat on the ground with blue pointing out of the face you want away from the wall, rotate the component 90° so that face is vertical, then run Copy Along Path set to Road-like. If a copy still flips, explode the path and nudge one vertex a hair off the perfect plane so the tangent is no longer exactly vertical, then straighten that vertex once the copies look right.
The team have been looking at this issue, and I think they see it as something they should fix soon.
We do have SKOR-22813 logged as a bug report for this now.
Colin’s orientation setting is worth checking first: in the Copy Along Path controls, try Road-like rather than Stair-like. Stair-like keeps the object upright, while Road-like allows pitch as well as yaw, which is what a vertical run needs. To isolate the axes, test with a tiny asymmetric component (for example, mark one face) on a straight vertical segment first. Set its red axis along the path tangent and use the blue/green axes to define which way the component’s upright face should point. If that works on the straight segment but not the arch, check that the arch is being treated as one continuous path and that the starting tangent is the one you expect.
