Background on/off toggle in Layout does not change background. Why not?
Background on/off toggle in Layout does not change background. What could be preventing this?
Depends on the style used. Can you share the LO file so we can see what you’ve got and help you get it sorted?
What version of SketchUp are you using? Please complete your profile.
Having trouble uploading file.
I didn’t realize that some styles do not allow turning off the background.
I’ll try different style
I updated my profile
Probably too large to upload here. You can upload to Drop Box and share the link. If the file contains sensitive info (clients or yours) you can send it in a private message. I won’t share it publicly.
Thanks. That provides helpful information.
https://1drv.ms/u/s!Anh_dt79766Wh-MOxOZYh9YYdH7dqA?e=aqIVJf
see if that link to a onedrive file works
Turn off the Sky in the style and then update the style by clicking on the thumbnail in the upper left corner of the Styles panel. Save the changes and update the reference in LO.
Note, if you want to show scenes like this one to scale in the LO document, set the Camera to Parallel Projection for the scene.
As I always do when I get files like yours, I poke a little bit. I found and fixed some incorrect tag usage in the SketchUp model. ALL edges and faces should be created and left untagged. Only components and groups should get tags.
Screenshot - 5_18_2021 , 11_38_54 AM
I also purged unused stuff from the SketchUp model…
Screenshot - 5_18_2021 , 11_41_15 AM
…which reduced the size of both the SketchUp model file and the LayOut file by 63%.
DaveR,
Thanks VERY much. Been using Sketchup on and off for years but now trying to really master. I never would have guessed that the sky being on would have done it but you are indeed correct.
Also, thanks for the other recommendations. Tags are something I just started using and I will follow your recommendations. I could tell the file was sluggish. The model actually has much, much more than what this scene shows, so cleaning it up will make a big difference.
Thanks Again!
Happy to help.
FWIW, Purging unused does not get rid of anything that is actually being used in the model. If there’s stuff in there that you don’t need after doing the purge, get rid of it, too. Then do another purge.
