Either the Preserve Drawing Origin was not checked when you imported LotLines, or the files have a different origin point.
BTW, you are using some wrong import unit, perhaps inches instead of feet. However, using the Preserve Drawing Origin option with a larger import unit may result in your model ending up far too far from the SketchUp model origin to be practicable.
Agree with Anssi… its most likely your base autocad drawing… do you have multiple UCS coord systems in your dwg/s ? Or you missed toggling preserve base coord or assumed wrong base unirs on import, all simple to correct…
When I imported both files, making sure that “Preserve drawing origin” was checked for both, they got placed neatly on top of each other. Untitled2.skp (141.1 KB)
Thanks Anssi. I think I’m missing something or barking up the wrong tree.
Also, any idea why both files import so far from origin point, even though you specified ‘preserve origin point’? From your file I had to zoom extents to view up close. But not an issue, just wondering why this occurs? Thank you.
It is the AutoCad origin point that is preserved. The option places the AutoCad origin at the origin of the SketchUp model. The origin in your DWGs is far from the content.
