Glad that worked for you! There is something going on in your set-up , though, it might have something to do with the way you onstalled SketchUp in the first place.
Since the release of SU 2017, there has been a tidal wave of posts from people who encountered problems with SU because they did not install it properly on Windows. The only correct way is to right-click the installer and select “Run as Administrator”. It is not enough to be logged on as an adminstrator.
This requirement (which is not unique to SketchUp) is because modern OS’s have upped their security requirements to protect against malicious code that tries to modify crucial system areas su…
