Is there any way to make an attribute table, which need to include something like OmniClassCode. And it is going to be something like this after exported to IFC4.
Yes, you can use a few plugins:
Bsdd Building Smart:
Ifc Manager:
Rtches Bim utilities:
Thank you for your reply.
But from the IFC Manager, i can only find the way to set “IsExternal”. I do not know am i using this extension correctly.
The IFC manager adds the common property set for the 27 classes that are generally used, and can add classifications for the Netherlands (NLSlb) and Germany (DIN …)
For Omniclass, I don’t know if there is a classification .SKC available, but that should be added separately (one can add multiple classifications on an object)
Check this post:
Have you restarted Sketchup after installing my plugin?
You should have a toolbar to show under “toolbars” menu
