In this build we’re introducing a new Graphics settings page for Multi-GPU systems that allows you to manage the graphics performance preference of your apps. You may be familiar with similar graphics control panels from AMD and Nvidia, and you can continue to use those control panels. When you set an application preference in the Windows Graphics settings, that will take precedence over the other control panel settings. Find the page by going to Settings > System > Display and scrolling down to the “Advanced graphics settings” link. (In future flights, you will see this link as “Graphics settings”.)
The first step is to choose an application to configure. Choosing a “Classic app” will let you browse to an application on your system. Choosing a “Universal app” will let you choose a Store application from a list. By default, the application added to the Graphics settings page is given a “System default” preference. System default means that the system decides the best GPU for your application.
Picture of advanced graphics settings page in Settings. You can choose an app to select graphics performance preference – there’s a dropdown to choose between classic app and universal app.
https://winblogs.azureedge.net/win/2018/02/d7ce934824f7922ff5a22965bbf68c5b-1024x640.png
Once you’ve chosen the application, click on the application in the list and then click the “Options” button. The “Power saving” mode is a request to run the application on the most power saving GPU available. The “High performance” mode is a request to run the application on the most high performance GPU available. Generally, the power saving GPU is the integrated GPU on a system, and the high performance GPU is the discrete GPU or external GPU. If you have both a discrete GPU and an external GPU on a system, the external GPU is considered the high performance GPU.
Remove an application from the list by clicking the application and clicking the “Remove” button. Removing an application is the same as choosing “System default”.
Graphics specifications popup, showing the option to switch graphics preference between system default, power saving, and high performance.
https://winblogs.azureedge.net/win/2018/02/51dc97e5190081fa9dda832b39ddc65d-1024x716.png
Applications are always allowed to have the ultimate choice of which GPU to use, so you may see additional applications that do not follow the preferences you set. In that case, look for a setting within the application itself to choose a preference.
