All Objects Disappeared from Model, Workspace Screen completed white without warning. 'Fix Problems cannot find any errors
System Technical Specs: GeForce RTX4070, 32 GB DDR5 RAM, 16 core i7 CPU,
Sketchup Studio 2024
Title is pretty much the long and short of it while working on the attached file, the workspace screen went blank without warning, any and all objects I had modelled are not visible, but do appear in the components tab, model info also shows the file contains the same amount of edges & faces as before. I’ve tried zoom extents and trying to use the standard view options + existing scenes to return to a view of my project but have had not succes.
I also have already run the Sketchup.exe and used the ‘repair’ option to no effect, copying the file and opening the copy did did not help either. Any bug splat reports from the 1 or 2 crashes I had were sent.
One Drive Link to the file can be found below. Was slightly to big @ 17.9mb
CS67 - Structure Inc Topographic Site Model 08.08.24.skp
We can’t access the file to be able to help you. The company requires sign in credentials. Put the file on DropBox or somewhere else accessible.
Sorry I thought I had changed the access settings to make it accessible to anyone with the link. Will put it in the dropbox right now.
File is located here, access is set to be available to anyone using the link. Can try using Megasync if this doesnt work
That works. Give me a few moments.
No problem,
Appreciate the quick response
Here you go. The main part of your problem is your style setup has Ground turned on with almost no transparency and set to show from below. The camera was positioned below the ground plane and the model is above it. I left the axes visible, too. They are useful for being able to make sense of where the camera is located and facing. And I purged unused stuff and reduced the size of the three huge texture images.
CS67 - Structure Inc Topographic Site Model 08.08.24 rescued.skp (11.5 MB)
Thanks very much.
