I’m helping Andrew (@Quadhurst) to draw mid 20th century street light columns and lanterns.
This image and attached SU file represent part of a cast iron column.
Embossing.skp (373.5 KB)
The intention is to draw it at full size (as dimensioned) and to have it 3D printed at 1/10 scale on a laser 3D printer with a resolution of about 0.1 or 0.2mm - so the detail of the embossed part of the casting can’t be too great.
The embossing is mirrored on two opposite sides of the column.
There appear to be 16 copies in the ring of ‘bulges’ just at the level of the 8" dimension line.
The embossed pattern covers about 3/8 of the perimeter - 6 of the bulges.
How might we best draw the embossed part of the column?
Try to draw half of one side it directly on a 16-segment cone, then give it thickness and mirror the result?
Draw it flat, then using a Bend extension to curve it round the conical under-shape?
The printer has limited resolution so one can’t make the embossing too detailed.
