Creating a Style to mimic old ironwork sketch drawings
Hi Guys n Gals,
I have just started work with artistic blacksmiths producing their 3D models to showcase their work to their clients and the world. Ideally, drawings issued should look to be in the old style of ironwork sketches as in the attached. Is there any filter I can apply that would come close to producing this kind of effect or is there a way of creating a new Style that I can use as a template to produce client drawings?
Any help would be very much appreciated.
Kindest regards
Patrick
You’ll need to work with SKP Styles and then use LayOut to create the title blocks / pages.
Lots of stuff on the YouTube
Do you mind sending me a sample model so that I give it a go?
M.
@DaveR has worked a lot with the StyleBuilder application and has created similar things to what you want to achieve. He might have some hints.
Ironwork gate and filter style example.skp
Hi Majid
Sure. Thanks for having a look.
Kind regards
Patrick
@Depth3d you need to make the file available. Currently I get an access denied message.
Does something like this come close?
Shaft Hanger soft
Here’s a different rendition.
Shaft Hanger Old Paper
Rotunda.skp (14.2 MB)
Hi Dave
Yes, the Shaft Hanger soft is getting very close to what we’re looking for. The Old Paper version is too “clean”.
Patrick
As was suggested, you could use Style Builder to create a style with the edge style you need. As I told you in my reply to your PM, you would also need to do some post processing. I made a couple of image exports from SketchUp, one with just the shading and another with just the sketchy edges. The shading version was run through a filter to create the sketchy look and given a bit of blur to soften it. The edges and the sketchy shading were combined with the image of old paper for the final.
In the case of the second image, I created a watermarked style using the same sketchy line style and the paper image. There were two image exports; one with the watermark and another of just the shading which was filtered to create the sketchy shading.
That image can be “dirtied up”.
FWIW, I think you will need to clean up your model quite a bit and probably increase the number of sides in the curves.
This is a quick example. I’m sure it’s not exactly what you want but hopefully it gives you some ideas.
Hi Dave,
looking good. I managed a quick export from AutoCAD to Sketchup, hence the rubbish curves and had to delete a lot of the model to bring the file size down to upload it to the forum.
Thank you very much for your time on this. Much appreciated.
Kind regards
Patrick
Dave had already done a great job and his comments are valid…
Dave! These are gorgeous! How do we get these styles? can you send over a model with the styles embedded?
Thank you Rod.
There are a bunch of my sketchy line styles available from Sketchucation but a lot of what I did in the images I showed here are done in post. None of it is difficult. I described the process briefly in a post a few up from yours.
Sooo… errrmmm… RIP StyleBuilder?
I just got an email about that. I guess I won’t be uninstalling SU2024.
I can kind of understand it being discontinued. I expect few SketchUp users even bothered to open it let alone use it. There’s been no updates to it since it was released (although I don’t know what would need to be updated) and if they get rid of it, no one on the team has to be concerned about whether or not it still works with current operating systems and such.
best solution would be to have it available as a standalone app in the “my product” section of our account.
I think you’re the first person I’ve met that actually used it. took me 15 years to find someone.
on a mac, you could just delete the app from the app folder with no repercussion.
I have made a lot of sketchy styles with it over the years.
It seems more often than not when someone asks about it they are wanting to know how to get rid of it because they don’t know what it is.
I am a PC lover, and thanks for the acknowledgment.
I use and like standard styles but not the pencil edges - I come from an illustration background and having the ability to add my own hand drawn edges has really helped the models have that extra custom/bespoke look. Understandable that I may be the only one using style builder as its obviously an old clunky thing … old things being made redundant… its all so ageist these days (slightly sarcastic humour intended)
I read this as my own post (lol) its exactly how I feel.
will we be able to load into SU25 and future versions, styles that we’ve made from style builder previously? coz that’d be okay by me as a consolation.
