Advanced scaling
Hi Im on Sketchup Make.
I have created this door, currencly its a Group with sub groups.
I need to scale it to fit for another doorpost, along all axes. But I do not want to change the ratio or size of the profiles etc. How can I do that?
FredoScale is your best friend in this case.
Of course it can be done without plugins, but you need to go in each Group or Component and stretch usig the Move tool or scale them individually.
If you have the Pro version you could also create a Dynamic Component of the door which would be able to scale correctly. This is a good option if you are going to be using this component often and in several different frame sizes.
Thansk will check out the FredoScale plugin as a start
