Somebody sent me easy to follow instructions on uploading materials to my material drawer, but I can’t find it. Still, I managed to get Dunn Edwards into materials, but the color is incorrectly displayed.
I’m importing Dunn Edwards paint, which I did using a link I found years ago. Problem is, the colors are not true. To isolate the problem, I checked the dunn edwards website for the color, Hex Codes, Name, and DE ID code. The color from the site exactly matched its reflection in RoomSketcher. There’s a visual match between the hex code from DE, as input to RoomSketcher’s but not with the DE colors uploaded to for Sketchup->materials->colors.
I think there is a sequence that must be used, and don’t you know I can’t find it. Can you help me get the correct way to import paint, wallpaper, and fabric to sketchup?
Colors will often display differently in SketchUp due to the way shading is done to imply the 3D-ness of the model. You can experiment with using Sun for Shading and adjusting the Light and Dark sliders.
Thanks, Adam. It’s time I learned to work with that feature anyway. I did go to ->shadows (window tray) and enabled Use Sun For Shading. The settings were originally on 80 light, 20 dark. I did have to reset them after I enabled Sun…
Since you are versed in shading, may I ask how my time in UTC should be set. The timeline slider indicates noonish, which is correct for my PST frame where I live. Also Display is grayed out, but on faces and on ground are selected.
Gotcha. Thanks again. I’m onto working through this now. I have other problems. I can not link my “local collections” file to my locale collections file in file Explorer. But, now I’m working on making sure my materials are entered correctly.
Thank. I actually cut the photo at the repeat pattern point, resized it in Sketchup, and it worked!! Could hardly believe it. Now, if I could only get the link between my computer and default tray → materials → favorite collections to work, I’d be so happy just now. The favorites file cannot seem to fully connect with my saved stuff.
You can create a template creating new materials and adding them to the file, then every time you open that template all the materials you’ve added will be on the materials tray clicking on the house icon, materials in the model. I don’t know if it’s possible to create a new materials folder in the materials file app data.
