Hello,
I’ve been having a problem with the add location tool. I hardly use add location tool but for the project I have for monday 17th I have no choice. When I press the icon it freezes the use of the program chiming when I click. Using SKup 2024 and it is all up to date. I uninstalled the add location tools and reinstalled it .I also uninstalled the SkUP software and reinstalled it as admin. Still having the same issue. Any one else having this issue?
The chiming tells you that the windows is open, but you’re not seeing it.
When you are hearing the chiming, type Alt-Spacebar, then M, then press any arrow key. The missing window should then be attached to the cursor, so move your mouse and when you see the window, left-click to drop it off where you want.
The ‘M’ is the shortcut for Move. If you are working in Spanish it should still be M, but other languages may need a different key for that step.
