When clicking on add location my map does not show up, Using SU2024
Not sure if anyone else has had this problem but I have tried using the add location in SU 2024 and when I click on it, the map doesn’t open like past versions. Then I’m locked up and can’t do anything and have to manually kill the program. Anyone else with this issue? Kind of need the map to do some work. Thank you.
There was an issue a few weeks ago, and the extension was updated to fix the problem. Open Extension Manager, and in the Manage tab see if there is an update for Add Location.
Hi Colin,
Thank you for the quick response. Unfortunately, the update is grayed out and it is set to enable.
Try installing Add Location (2024 version) from the Extension Warehouse directly. Then quit and restart SketchUp.
updates the add location still isuue exist
Thanks for the report @Shiplift2024 . If you use the geolocation / addlocation tags you should get a more timely response as we monitor those tags.
What do you mean by locked up? Can you not close the add location window?
Thanks,
Dan
