I do not have the place in your video that shows the above measurement
Itâs normally at the bottom right corner of the screen. Maximise the SketchUp window and you should see it.
Again when I open your file you have the camera almost 107 Kilometers out. Could you see a real 10 cm square from 107 Kilometers?
When you talk about zooming in too closely, are you talking about when the camera clips the model?
Zoomed out:
Zoomed in:
You may want to check your mouse settings, namely your DPI and your scroll wheel sensitivity if possible. It seems your small movements are translating into large camera movements, if Iâm reading you correctly.
I donât think weâve gotten to clipping here.
The OP is standing on the Rock of Gibraltar trying to see a 10 cm square in MĂĄlaga, Spain.
He mentioned not being able to rotate the model when he zooms in too much. I figured that was what heâs referring to, but it seems thereâs something more fundamental going on here. Itâs like he doesnât understand the zoom function is relative. If I have my cursor over an object and zoom in or out, it does so at a different rate than when my cursor is over nothing. Itâs like when you delete the default scale figure before laying down any part of your model and move the camera around; it can be a little unruly and hard to reorient yourself.
Maybe but heâs also got his model at a large distance from the origin and other problems.
Yes. Thatâs normal. Zoom Extents is a useful way to deal with that unless you scatter little bits of geometry all over the place as in the OPâs model.
OK. Now you have a box that is 10 cm wide. Go to the Camera menu and click on Zoom Extents.
So did you do as Box indicated and set the correct units for the .stl export? Clearly the slicer is expecting millimeters for the import units. Model in SketchUp using millimeters and export the .stl with units set to millimeters.
If youâre working in cm but the Slicer is expecting mm, you can also just scale up the model in the Slicerâs menu. Since youâre working in metric, itâs a cinch to just go by tens.
Youâll just have to rescale the original file if you want to share it to a repository like Thingiverse or at least add a note to it about how it should be scaled or what its proper dimensions should be.
Thank you all
