Would it be a too big violation of UI guidelines if the file tabs were put in the application header like Chrome does? That space is mostly sitting there doing nothing…
well, in fairness, if you deactivate the scene tab, you get a bit of space back on the right one but yeah, it used to appear only if you had scenes, now it’s by default. or not at all if you turn it off.
I find the file tabs more annoying, like mentioned before, they should go up like a browser. plus, having file and scene tabs separated would limit the confusion during training sessions. there are 2 lines of tabs, both with the same (+) symbol, stacked on top of each other.
One thing that did change is that previously there was a problem with use fast feedback, where if that was turned on there were problems with antialiasing >0x. In 2026, having use fast feedback selected would force you into 0x. In 2027 you can have use fast feedback turned on, and still choose 4x.
Thanks @colin I didn’t even think to check what the default value is (brainfart I guess) because why would it be set at ‘0’ out of the box on fresh install?! Changed to 4x and it looks better now.
I wonder if 2027 is still resetting to 0x on first launch, if use fast feedback was on, even though with Qt it seems not to be needed. I will check with Thayer.
I like having scene tabs. As others here have pointed out, I’d rather disable the ‘session’ tabs since on Mac, you could always run multiple sessions and copy and paste between or switch between them via Espose or Window/filename…This was a problem on PC that was solved and the UI unification forced mac users to adopt something that was (to me) never a problem!
Agreed @Anssi - see my 1 min mock of how SU could have fixed this. Why do the devs not treat every pixel of working screen real estate as sacred? CAD even has a ‘clean screen’ mode where you can focus on just the workspace. Even allowing for opacity sliders on the default tray - that now takes up 20% of the screen could let users see what’s underneath instead of shoving everything to the side. Man I have so many good ideas if the Trimble team ever wants to hear them
when you read the “official” discourse on this topic, it makes sense to do tabs like you’re showing.
overall, there are many small things to buff out, on pc as on mac, starting with contrast and wasted space (I know that out there, Dezmo approves this message )
BUT.
as a trainer, my god I’m grateful for the unified UI. I can train PC users on my Mac, and I don’t get call from PC/Mac users asking me “how do you do this and that on a Mac/PC”
Idk if you’ve seen What Boris is cooking with QT, it seems that on the long run, it’ll open a lot of possibilities for custom UI.
(unfortunately, I’m kinda stuck with the default one until I stop teaching ^^')
Well, while I did mark @colin answer as the solution but every time I re-open SUv2027 the graphics aliasing reverts back to 0. Pretty annoying to have to set each and every time!
It does seem that Mac users have lost a few of the good reasons we used Mac in the first place in the name of “unification”. Feels more like lowest common denominator. Let’s hope some the chunky feel and wasted space gets refined in the coming iterations of the new UI, and that we get more options to customize which bars and tabs we want to see.
That may still be a combination that can’t work. If you need to use the classic graphics engine for something, and you need antialiasing, don’t use fast feedback. Staying in the new graphics engine should work ok.
