Styler - an extension to restyle SketchUp 2027 user interface (prototype) - MacOS Only
Hi everyone,
Here is Styler, an experimental extension that changes how some parts of SketchUp’s interface looks.
→ Download Styler
How it works
Since version 2027, SketchUp’s interface is built on a unified base made with the Qt framework. Qt lets you style its widgets with style sheets, much like CSS for a web page. Styler uses this: it builds a style sheet from your settings and applies it to the main window. Every change shows up live, with no restart.
What you can customize so far:
  • toolbar buttons (hover, checked, pressed), the toolbars themselves and their separators;
  • the area behind the toolbars;
  • document tabs and the frame around the 3D view;
  • scene tabs;
  • the status bar;
  • the title bar color.
Each section has its own switch. If you turn one off, that part keeps its native look.
The goal
The aim is simple: let everyone have a clean, good-looking interface that suits their taste. You can lighten the frames, harmonize the colors and remove visual clutter so the model gets all the space and fix certain visual inconsistencies in the interface.
An experiment, first and foremost
Styler is a prototype. This kind of extension only became possible with the unified interface in 2027, and I wanted to see how far it could go. For now it is tested only on SketchUp 2027 for macOS (Apple Silicon). Anywhere else it reports itself as unsupported and does nothing.
Currently, only certain parts of the interface are customizable.
Open source
Styler is open source under the MIT license. The code is on GitHub, and contributions, ideas and bug reports are welcome:
I’d love your feedback: what you’d like to customize, the themes you have in mind, and any issues you run into.
→ Download Styler
Happy testing :sun:
This inspired me to see if I could replace the new tool cursor icons with the classic ones by interrogating QT.
Initial results are promising…:slightly_smiling_face:
THis is very neat! Thank you! Flattening the UI using your tool makes it look a bit like sketchup web, in a good way…
Question, is there an option to style the left-right arrow buttons in the scene bar?
Before 27, I could go and adjust some ui elements and content from xcode, editing .nib files. This is no longer possible. Any way of modifying the tray windows, and other ui elements?
I just publish a new release 0.1.2 where you can customize the MessageBoxes, ScrollBars and Palette.
This will affect tray windows too.
Wow! really nice!
Dark mode, kind of… Native icons are not there yet, unfortunately. Not going too dark will help. Or maybe a background for them.
I dabbled a bit, but could not find where to style the palette titles or X button.
The color picker’s eyedropper does not work I believe, or not outside its window.
We don’t have control over everything. However, the “Selection” field does influence the “X” button. Leaving it blank allows for the use of the default pale blue style, which is also defined for the toolbar icons.
@caronte01, if you update to 0.1.3, you will be able to Export / Import your presets. Maybe you would share your Dark Mode preset to the community :slight_smile:
And I could add it as a second default preset…
Way to respond to new opportunities @boris.beaulant This is great access to customizing the look and function. Thank You.
Here you go. This is a first iteration on creating a macos dark style, with blue selection and highlights. I didn’t go very dark, to try and keep our current icons visible against the background.
I could not find how to change the palette text title color. Other than these minor things, works great!
I found myself editing these values constantly:
  • Background (different names in each section)
  • Normal
  • Selection
  • Hover.
Could you consider adding a global setting option for these, so we don’t have to go into each section changing them to match?
Dark Mode.json (5.0 KB)
That is more like Dingy Mode. (Too light for me.)
Thank you @caronte01!
0.1.4 - 2026-11-02
Added
  • Built-in presets: five ready-made themes in the Presets card: Styler BlueSky (the default look),
    Styler Graphite, Styler Steel, Styler Night and Styler Sand. They are read-only, and a saved preset
    cannot take one of their names.
  • Preset state: the last applied or saved preset is marked applied, then ● modified as soon as a
    setting changes.
  • Preset actions: a ⋯ menu on each saved preset with Update with current settings, Rename
    (in place), Export… and Delete. + Save current… saves the current settings as a new preset.
  • Toolbars — normal button color: background and border for buttons at rest, not only the hover,
    checked and pressed states.
  • Toolbars — move handle: the grip of docked toolbars can stay Native, be redrawn as Dots in a
    chosen color, or be hidden (None).
  • Scene tabs — search lens color: the magnifier left of the scene tabs can be recolored (normal and
    hover), with a faded version while the model has no scene.
  • Color text fields: every swatch now has a text field that accepts #rgb or #rrggbb (the #
    optional), none / transparent where offered, or empty to unset.
Changed
  • Applying a preset always turns styling on.
  • The toolbar background is now native by default.
  • The palette is on by default in the base theme.
  • The document and scene tab “strip” settings are renamed Background. Presets from earlier versions are converted automatically.
  • The settings dialog’s minimum width is slightly larger.
