2 Point Arc tool launches with "g" populating the number of sides in 2023
I’ve searched for this and haven’t found any discussion yet. When you activate the 2 point arc you normally can enter the number of sides and continue on. When I initiate the 2 point arc there is a “g” in the Sides display in the lower right corner that will go away when you start typing a number, but whatever number I use it doesn’t stick. Then when I create another 2 point arc the g returns but this time doesn’t go away and the numbers I enter will appear after the “g”. I have to hit backspace to remove the “g” then enter the numbers which will finally stick.
Yes, this has been reported for other tools such as the Zoom tool. The Backspace key is the current workaround.
