Having trouble with getting component attributes to work.
In my workflow, I create a component, then use the XYZ component attributes to “lock it” in place, generally in 2 of the axis directions. Commonly I use this with plan pages brought into the model and face objects used to represent window or door sizes. For instance, I’ll lock a component face, using it as a stand in for a window, in X and Z axis, locking it in position, and leave Y floating so I can move it to, say, face of plywood, or face of stud.
Trouble is, it simply won’t work reliably. Just tried doing it in a model I’m working on and, nope, I can move the object in all directions. Copy and paste in place the component into a blank SKP file, and now it works as expected.
This should be under the Dynamic Components topic. Hard to help without the offending file, or a file that replicates the problem behaviour. Can you post it?
Hey Right click Redraw recalculates/updates all the DC formula in the selected DC, which should correct your problem. Your video link is not working for me…
