I am using new iPad Air
Ver.15 The xray function not worrking even with enable button on. O
I am happy that xray works fine for you.
Any sage advice for me Steve. Perhaps a reinstall?
On a control labeled “I O”, the “O” position conventionally means “off”. Maybe taking it to mean “on” is the problem? In my screenshot you can just make out the visible “I” if you zoom in.
I tried it with a numder of other files on my pad. Same result. Update!!! I just discovered that a double tap on the button does the trick. Not obvious . Thanks for your suggestion to consider the file itself as the culprit. Led to try other possibilies. Got lucky😁
