I am finally starting to work with scenes and changing bacground/pen style etc for presentations. How do I go back to my default settings to continue working on the file.
Pick the original style you were using. If you didn’t update the style after editing it, the unmodified version will be in your In Model styles library.
Dave,
I pick the default style and it’s not the original, I must have updated it
by accident. I am trying to get back to the original, “Default colors,
shade with textures facestyle. White Background” and “straight lines” (no
weight).
Thanks
Michael Collins
Sharp Property Solutions, LLC
Architect/COO
852 Sharp Drive, Unit N
Shorewood, IL 60404
Office 815-664-3358
Cell 815-693-8101
Fax 815-664-3358
VIEW COMMERCIAL http://www.buildsharp.com/sharp.mp4
https://www.facebook.com/pages/Sharp-Property-Solutions/311055615605456?promoted_like=1&ref=RHC
In the customise toolbar, add the ‘styles’ tab to it. second from left on that tab is ‘shaded with textures’ which is probably the standard you are previously using.
Mike, is the style you normally use available in the Default styles library? If it is, you can select it from there. If not, is it your default template style?
When I open a new drawing, my “default” is what I described above. However, under straight lines there are no default settings, do you know what the default line style is. When I click on default the lin style seems correct but the background is not white.
The default style depends upon the template you selected and whether you modified it at all. What is the name of the style in your blank SketchUp file? You can see that in the Styles window.
I am using the used the Construction Documentation - Feet and Inches template
When I open that template, the default style is Shaded with textures. It’s available in the Default styles library.
But how do I get to the white background, no sky. I really appreciate your
patience.
Michael Collins
Architect/COO
Shorewood, IL 60404
Office 815-664-3358
Cell 815-693-8101
Fax 815-664-3358
Thanks Dave, i was able to get it right, is there a video would recommend
for working with styles, edges etc.
Michael Collins
Architect/COO
Shorewood, IL 60404
Office 815-664-3358
Cell 815-693-8101
Fax 815-664-3358
I haven’t seen any videos specific to working with styles and edges.
We could talk, later. Perhaps I can give you some tips.
That would be great, I am fairly new to SU but I did take Daniel Brown’s 2
day seminar.
Michael Collins
Architect/COO
Shorewood, IL 60404
Office 815-664-3358
Cell 815-693-8101
Fax 815-664-3358
Maybe I can call you when I get out of work.
Results of a browser search for videos on SU styles and edges
Click on the above phrase to go to the results!
Thank You very much!
Michael Collins
Architect/COO
Shorewood, IL 60404
Office 815-664-3358
Cell 815-693-8101
Fax 815-664-3358
